Use this procedure to configure FA Zero Touch Client auto attach.
  1. In the navigation pane, expand Configuration > Fabric.
  2. Select Fabric Attach
  3. Select the Zero Touch Client Auto Attach tab.
    From the Zero Touch Client Auto Attach tab you can configure a number of auto attach settings.
  4. Select Insert.
  5. In the Type field, select the ellipsis and select a client.
  6. Select Ok to select the client or Refresh to update the list.
  7. In the Isid field enter the I-SID value.
  8. Select Insert.
  9. Optional: To Delete a FA Zero Touch client select it from the auto attach table and select Delete.
Zero Touch Client Auto Attach Field Descriptions
Use the data in the following table to use the Zero Touch Client Auto Attach tab
Field
Description
Type
This column describes the type of client assigned to auto attach. Available FA client types are:
  • Wireless AP (Type 1)
  • Wireless AP (Type 2)
  • Switch
  • Router
  • IP Phone
  • IP Camera
  • IP Video
  • Security Device
  • Virtual Switch
  • Server Endpoint
Vlan
Specifies the VLAN ID component of the I-SID-to-VLAN assignment.
Isid
Specifies the I-SID value of the I-SID-to-VLAN assignment.
